[mapguide-trac] #555: Area feature labeling code does not check for
NaN values from centroid computation
trac_mapguide at osgeo.org
Wed May 14 17:30:52 EDT 2008
#555: Area feature labeling code does not check for NaN values from centroid
computation
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: General | Version: 2.0.0
Severity: major | Keywords:
External_id: 1078034 |
The new stylization code which computes labels for polygon features calls
a method which computes the centroid of each feature. In some cases this
method fails (when it can't find a good centroid which falls inside the
polygon feature's bounds), and it then returns NaN values for the centroid
coordinates. The labeling code, however, doesn't check for this
condition.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/555>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
