[mapguide-trac] #563: Strange thing happening when saving (on close) a layout
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 18 09:55:24 EDT 2008
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  major      |    Keywords:
External_id:             |
 - Comments from the original report:
 What steps will reproduce the problem?
 1. Edit a layout
 2. Close using the big red x button
 3. When the program asks if you want to save, hit <enter> (rather than
 clicking "Yes" with your mouse)
 What is the expected output? What do you see instead?
 Layout should close and be saved...what happens, though, is that the
 layout
 is saved, closed, and then re-opened.
 What version of the product are you using? On what operating system?
 1.0.3006.19897,
 I can reproduce.
 The problem is that the messagebox should "eat" the keypress, but it does
 not.
 When the layout closes, the tree gets the focus, and the keypress.
 It only happens if the layout is the only open item.
 Not sure how to fix it though.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/563>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
