[mapguide-trac] #567: Custom fusion widget error
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 18 10:03:15 EDT 2008
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  major      |    Keywords:
External_id:             |
 There is a problem when the new widget is added.
 The editor should display at least the "Script" property in the grid, but
 it does not.
 It should also switch to the correct editor after creation.
 Entering it manually does not help the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/567>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
