[mapguide-trac] #574: Polyline layers with more than one thematic
rule can't be hidden
trac_mapguide at osgeo.org
Tue May 20 16:01:21 EDT 2008
#574: Polyline layers with more than one thematic rule can't be hidden
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: General | Version: 2.0.0
Severity: major | Keywords:
External_id: 1070619 |
The attached layer definition XML is an example of the problem. There are
two line rules corresponding to a theme. The second rule does not have
any line symbolizations, and therefore no features satisfying that rule's
filter should render. But the stylization code does in fact render these
features using a default (solid black) line style.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/574>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
