[mapguide-trac] #580: Can't save my map
trac_mapguide at osgeo.org
Tue May 27 11:29:35 EDT 2008
Reporter: andrewd | Owner: ksgeograf
Type: defect | Status: closed
Priority: high | Milestone:
Component: Maestro | Version: 2.0.1
Severity: critical | Resolution: fixed
Keywords: | External_id:
Changes (by ksgeograf):
* status: assigned => closed
* resolution: => fixed
Comment:
I see. There is another problem, and it is group related. Every layer must
have been in a group, otherwise it won't save. Its a bit tricky to fix
without editing the xml.
You can create a dummy group.
Then put each layer/group into the dummy group, and back into its place.
Once you have done so with all layers/groups, remove the dummy group.
I have comitted the fix, so it will be in the next version.
If it still does not work, please reopen the ticket.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/580#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
