[mapguide-trac] #582: coordinate system selector has no built
in systems
trac_mapguide at osgeo.org
Thu May 29 14:19:17 EDT 2008
#582: coordinate system selector has no built in systems
Reporter: stevetech99 | Owner: ksgeograf
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version: 2.0.1
Severity: minor | Resolution:
Keywords: | External_id:
Comment (by ksgeograf):
I belive the problem is not with Maestro, but with MapGuide Open Source.
Can you try to go to this URL:
http://localhost/mapguide/mapagent/csenumeratecategoriesform.html
When you click submit, you should see the avalible categories. If not, I'm
guessing the file "categories.txt" is in the wrong place (it apparently
has to be in multiple places).
I have a bug report for that here:
http://trac.osgeo.org/mapguide/ticket/545
I don't know how, but after placing the files at various places, it
suddenly showed up in the list.
As for the version number, the two numbers are not in sync. I have fixed
that for the next version.
Please let me know the results of the above test.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/582#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
