[mapguide-trac] #585: Maestro: Line styles are offset vertically 50 percent (or so)
MapGuide Open Source trac_mapguide at osgeo.org
Sat May 31 11:56:59 EDT 2008
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
Comment:
 Yes, I can see that. In fact it is even weirder, it changes display based
 on the position in the dropdown :).
 I have used the images from WebStudio for the preview. I should probably
 make a little script that generates these so I have more control over
 them.
 As a side note, it does not show the correct linestyle in the preview.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/585#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
