[mapguide-trac] #761: Annotation drawing should be faster when
display is dense
trac_mapguide at osgeo.org
Tue Nov 18 11:35:50 EST 2008
#761: Annotation drawing should be faster when display is dense
Reporter: louisewatson | Owner: louisewatson
Type: defect | Status: closed
Priority: medium | Milestone: 2.2
Component: Rendering Service | Version: 2.0.2
Severity: minor | Resolution: fixed
Keywords: | External_id: 1121643
Changes (by louisewatson):
* status: assigned => closed
* resolution: => fixed
Comment:
Fixed by submission http://trac.osgeo.org/mapguide/changeset/3462
The changes made to improve the annotation drawing speed were:
1. When text height is 3 pixels or less a line is drawn instead of the
text which would not have been readable. This action is controlled by the
value returned by the new SE_Renderer::OptimizeGeometry method. That is,
if OptimizeGeometry returns true, then it is OK to perform drawing
optimizations. If a renderer does not wish to use optimization, then it
needs to override the OptimizeGeometry method and return false.
2. The result of the call to RS_FontEngine::GetTextMetrics is now stored
in the
SE_RenderText object so that this data can be reused rather than
recalculated
when the text is drawn.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/761#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
