Re: [mapguide-trac] #773: Composite line styles don’t connect cleanly leaving a “black” join mark
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 23 20:12:57 EST 2008
 Reporter:  zspitzer           |         Owner:
     Type:  defect             |        Status:  new
 Priority:  medium             |     Milestone:
Component:  Rendering Service  |       Version:  2.0.2
 Severity:  major              |    Resolution:
 Keywords:                     |   External_id:
Comment (by zspitzer):
 Attached is the mgp of the composite line style bug where the lines do not
 join correctly.
 May have something to do with the rendering pass as in composite symbol
 styles, or the second (top) line needs a different end cap style (say
 square join) instead of round join as in the first line pass. Sometimes
 you want this to happen with a single line only not lines that join. Maybe
 the form where you set the composite line style could have line joins
 buttons added so the user can select what type they need for the feature.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/773#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
