[mapguide-trac] #719: Compile : DWFTK will not build
trac_mapguide at osgeo.org
Fri Oct 3 13:54:52 EDT 2008
Reporter: mwtoews | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Build System | Version: 2.0.2
Severity: major | Keywords:
External_id: |
I have tried following the instructions to install Mapguide on Ubuntu 8.04
(http://wiki.osgeo.org/wiki/Building_MapGuide_on_Ubuntu_8.04) modified for
MGOS 2.0.2, but I cannot compile the OEM component:
nohup ./build_oem.sh 2>&1 | tee build_oem.log
The errors are:
make[2]: Entering directory
`/home/gis/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfcore'
if /bin/sh ./libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I..
-g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-
compare -Wundef -Wstrict-prototypes -fforce-addr -finline-functions
-ffast-math -fno-strict-aliasing -MT BufferOutputStream.lo -MD -MP -MF
".deps/BufferOutputStream.Tpo" -c -o BufferOutputStream.lo
BufferOutputStream.cpp; \
then mv -f ".deps/BufferOutputStream.Tpo"
".deps/BufferOutputStream.Plo"; else rm -f ".deps/BufferOutputStream.Tpo";
exit 1; fi
g++ -DHAVE_CONFIG_H -I.. -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-
virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes
-fforce-addr -finline-functions -ffast-math -fno-strict-aliasing -MT
BufferOutputStream.lo -MD -MP -MF .deps/BufferOutputStream.Tpo -c
BufferOutputStream.cpp -fPIC -DPIC -o .libs/BufferOutputStream.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
BufferOutputStream.cpp: In member function 'virtual size_t
DWFCore::DWFBufferOutputStream::write(const void*, size_t)':
BufferOutputStream.cpp:192: error: expected primary-expression before '?'
token
BufferOutputStream.cpp:192: error: expected `:' before ';' token
BufferOutputStream.cpp:192: error: expected primary-expression before ';'
token
make[2]: *** [BufferOutputStream.lo] Error 1
make[2]: Leaving directory
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
make: *** [all] Error 2
DWFCORE 1.0: Error build failed (0).................
Here is some information about the system:
$ uname -a
Linux gisserver 2.6.24-19-server #1 SMP Wed Aug 20 23:54:28 UTC 2008 i686
GNU/Linux
$ g++ --version
g++ (GCC) 4.2.3 (Ubuntu 4.2.3-2ubuntu7)
The version of MGOS is from
http://svn.osgeo.org/mapguide/tags/MAPGUIDE2.0.2
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/719>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
