[mapguide-trac] #721: Opened Fdo connection is not released (closed) correctly to DataConnectionPool.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 9 11:54:42 EDT 2008
DataConnectionPool.
 Reporter:  stevedang        |         Owner:  stevedang
     Type:  defect           |        Status:  closed
 Priority:  high             |     Milestone:  2.1
Component:  Feature Service  |       Version:  2.0.1
 Severity:  critical         |    Resolution:  fixed
 Keywords:                   |   External_id:  1131909
Changes (by stevedang):
  * summary:  Opened Raster Fdo connection is not released (closed)
              correctly to DataConnectionPool. => Opened Fdo
Comment:
 No, this defect is newly introduced by the recent server changes which
 generate subfilters when executing a select command. The fix technically
 applies to all providers. I will be working on the OSGeo.Gdal FDO provider
 stability via another ticket.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/721#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
