[mapguide-trac] #666: PostGIS FDO: connection problem with
PostgreSQL+PostGIS
trac_mapguide at osgeo.org
Fri Oct 10 05:44:19 EDT 2008
#666: PostGIS FDO: connection problem with PostgreSQL+PostGIS
Reporter: ssimoss | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Server | Version: 2.0.1
Severity: major | Resolution:
Keywords: | External_id:
Comment (by ssimoss):
== FDO::PostGIS ==
This is the dataconnection xml (using ''maestro'') with ''OSGeo.PostGIS''
provider:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.PostGIS</Provider>
<Parameter>
<Name>Username</Name>
<Value>demo</Value>
</Parameter>
<Parameter>
<Name>Password</Name>
<Value>demo</Value>
</Parameter>
<Parameter>
<Name>Service</Name>
<Value>demo at 10.1.1.150:5432</Value>
</Parameter>
<Parameter>
<Name>DataStore</Name>
<Value>public</Value>
</Parameter>
</FeatureSource>
test connection reports no error, but when I try to use this
dataconnection with a new layer I get:
MgInvalidStreamHeaderException.: Invalid stream header exception.
Exception occurred in method MgCommand.GetResponse at line 152 in file
Service/Command.cpp
and mgos 2 crashes with:
$ sudo /usr/local/mapguideopensource/server/bin/mgserver.sh
/usr/local/mapguideopensource/server/bin ~
Running the server interactively as an application instead of as a
service.
(3018266304) Server starting...
(3018266304) PROJ4 Coordinate System Library
(3018266304) Server started.
terminate called after throwing an instance of 'FdoCommandException*'
/usr/local/mapguideopensource/server/bin/mgserver.sh: line 7: 4941
Aborted (core dumped) ./mgserver run
== FDO::OGR ==
If I try to use OSGeo.OGR provider, which works (slow) with mgos 1.2, it
don't pass test connection:
Errore del server remoto: (559) MgFdoException.:
An exception occurred in FDO component.
Connect failed:
and server console complains:
service.
(3018061504) Server starting...
(3018061504) PROJ4 Coordinate System Library
(3018061504) Server started.
(2691959696) An exception occurred in FDO component.
Connect failed:
Exception occurred in method MgFdoConnectionManager.Open at line 858 in
file FdoConnectionManager.cpp
Now if I retry ''OSGeo.PostGIS'' test connection I get the #666 error
message.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/666#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
