[mapguide-trac] #729: Add support for flagging base map tile cache never to be purged
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 23 15:18:53 EDT 2008
 Reporter:  zspitzer      |         Owner:
     Type:  enhancement   |        Status:  new
 Priority:  medium        |     Milestone:
Component:  Tile Service  |       Version:  2.0.2
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by tomfukushima):
 There should be a single spot where the tile cache is purged by the
 server.  It should be pretty straightforward to add a check to see if the
 header flag is set.  I suggest that if you can find someone to do this
 (perhaps yourself) that you create an RFC, get it approved, and then
 submit the patch.  I doubt that this will take much effort to code up.
 Tom.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/729#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
