[mapguide-trac] #740: GETSPATIALCONTEXTS and GDAL Always Returns
Default Extents
trac_mapguide at osgeo.org
Tue Oct 28 07:22:47 EDT 2008
#740: GETSPATIALCONTEXTS and GDAL Always Returns Default Extents
Reporter: crispinatime | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Feature Service | Version: 2.0.2
Severity: major | Keywords:
External_id: |
I have been trying to debug Maestro wondering why when a raster config
resource file is built it always contains bogus extents (-10000000 to
10000000).
I finally traced through to 'GetSpatialContextInfo(...)' which has created
a temporary session resource to query via the MapGuide API - as far as I
can see on my layer set-ups it is GETSPATIALCONTEXTS that is at fault.
I have tested the file with GDALinfo.exe to confirm the extents are
returned OK by the GDAL14.dll.
To recreate (for example) add a raster file to a GDAL composite feature
source in Maestro and put a braek point in HttpServerConnection.cs at line
922 to step into the call and see the extents generated.
Or simply edit the FeatureSource in the second URL below:
C
http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSPATIALCONTEXTS
&VERSION=1.0.0
&SESSION=5360ba88-0000-1000-8000-001422f493b1_en_7F0000010AFC0AFB0AFA
&FORMAT=text%2fxml
&RESOURCEID=Session%3a5360ba88-0000-1000-8000-
001422f493b1_en_7F0000010AFC0AFB0AFA%2f%2fccbeeed0-d467-41c9-a439-
8d7fc84593bc.FeatureSource
&ACTIVEONLY=1
&LOCALE=en
Can simplify for any GDAL resource you have with the following
&VERSION=1.0.0
&FORMAT=text%2fxml
&RESOURCEID=Library://Test/Data/NS66.FeatureSource
&ACTIVEONLY=1
&LOCALE=en
Always returns extents like below (non-GDAL feature sources return good
extents)
<Extent>
<LowerLeftCoordinate>
<X>-10000000</X>
<Y>-10000000</Y>
</LowerLeftCoordinate>
<UpperRightCoordinate>
<X>10000000</X>
<Y>10000000</Y>
</UpperRightCoordinate>
</Extent>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/740>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
