[mapguide-trac] #678: Vertical Extent of Rendering Excessive -
or Labels 'Apparently' Missing
trac_mapguide at osgeo.org
Wed Sep 3 12:30:13 EDT 2008
#678: Vertical Extent of Rendering Excessive - or Labels 'Apparently' Missing
Reporter: crispinatime | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.0.1
Severity: minor | Resolution:
Keywords: | External_id:
Changes (by crispinatime):
* summary: Vertical Extent of Rendering Excessive => Vertical Extent of
Missing
Comment:
Tom,
There is more - which I think justifies a 2.1 milestone.
Because labels are centred on the map - within a polygon for example - if
the user increased the size of a layout and then decreases it the label is
centred vertically on the erroneous 'max' Y and will therefore be off-
middle and may be off the visible map giving the impression that the label
was not generated (but pan-up to see it!).
I was going to add a "labels not always work" ticket until I realised it
was a different manifestation of the same issue.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/678#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
