[mapguide-trac] #695: Fix the xml external editor
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 12 03:55:17 EDT 2008
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 For non-obvious reasons, notepad.exe spawns another process. This makes
 the "Edit in external editor" button broken.
 The fix for the above should both fix the external editor problem, as well
 as make an option to select the favorite external editor, and perhaps
 decide to use that one exclusively.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/695>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
