[mapguide-trac] #693: PHP and ASP AJAX viewer fixes needed for simple search on NULL values - MgProxyFeatureReader.GetProperty line 448
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 12 09:33:14 EDT 2008
 Reporter:  cgountanis                                           |         Owner:
     Type:  defect                                               |        Status:  closed
 Priority:  high                                                 |     Milestone:  2.1
Component:  AJAX Viewer                                          |       Version:  2.0.1
 Severity:  blocker                                              |    Resolution:  fixed
 Keywords:  IsNull MgProxyFeatureReader GetProperty AJAX Viewer  |   External_id:
Changes (by cgountanis):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Beautiful work! I was able to confirm that the ASPX and the PHP do work
 with Null and !Null fields from the same feature source. Thank you very
 much! I will not be able to test JSP without complicating my IIS install.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/693#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
