[mapguide-trac] #689: EPSG Support
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 12 17:24:38 EDT 2008
#689: EPSG Support
 Reporter:  thomasknoell     |         Owner:  brucedechant
     Type:  enhancement      |        Status:  closed
 Priority:  low              |     Milestone:  2.1
Component:  Feature Service  |       Version:  2.0.1
 Severity:  trivial          |    Resolution:  fixed
 Keywords:                   |   External_id:
Comment (by brucedechant):
 That is a supported EPSG code so it should work.
 Can you confirm that the exact text for the coordinate system failure you
 are seeing is as follows?
 EPSG:27700
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/689#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
