[mapguide-trac] #546: Deselect and tooltips very slow in MapGuide
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 17 15:45:44 EDT 2008
 Reporter:  trevorwekel        |         Owner:  trevorwekel
     Type:  defect             |        Status:  reopened
 Priority:  high               |     Milestone:  2.1
Component:  Rendering Service  |       Version:  2.0.0
 Severity:  critical           |    Resolution:
 Keywords:                     |   External_id:  1072510
Comment (by trevorwekel):
 The following modifications have been make to query algorithm:
 - Only perform the query if a selection area can be calculated.  If the
 input geometry is a line, a centroid cannot be calculated.  This typically
 occurs outside of coordinate system bounds.
 - Intersect the selection area with the map extent and only process the
 query if the intersection exists.
 Submitted to 2.0.x stream under
 http://trac.osgeo.org/mapguide/changeset/3325
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/546#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
