[mapguide-trac] #702: WMS service DPI setting inconsistent with the
default used by MapGuide
trac_mapguide at osgeo.org
Fri Sep 19 12:27:45 EDT 2008
#702: WMS service DPI setting inconsistent with the default used by MapGuide
Reporter: chrisclaydon | Owner: chrisclaydon
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: WMS Interface | Version: 2.0.1
Severity: trivial | Keywords:
External_id: |
!MapGuide uses a default screen resolution setting of 96 DPI. When the WMS
service creates an !MgMap object to render a requested map image, it sets
the DPI value to 72. This results in incorrect scale calculations, which
can result in the wrong layer style being used at a particular scale.
The WMS service should leave the DPI setting at its default value of 96.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/702>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
