[mapguide-trac] #419: Composite line style element selection bug
trac_mapguide at osgeo.org
Fri Sep 19 22:36:38 EDT 2008
Reporter: skorpion | Owner: tonyfang
Type: defect | Status: closed
Priority: medium | Milestone:
Component: General | Version: 2.0.0
Severity: major | Resolution: fixed
Keywords: | External_id: 1055212
Changes (by tonyfang):
* status: assigned => closed
* resolution: => fixed
Comment:
http://trac.osgeo.org/mapguide/changeset/3333
When a polyline with a composite line style is stylized, it breaks up each
style, and renders each style individually. See
DefaultStylizer::StylizeVectorLayer. So it ends up calling StylizeVLHelper
for each style. This makes the composite line style ?\226?\128?\152look
nice?\226?\128?\153.
E.g. If you have road network, and you use a really thick red line style
and a thin yellow line style ?\226?\128?\147 you will see the thin yellow
line segments all connected together. Otherwise, the red thicker outer
line will surround each line segment ?\226?\128?\147 and the thinner
yellow line segments won?\226?\128?\153t appear connected.
When you select a feature, RenderForSelection calls StylizeVectorLayer,
and goes through the above mentioned code. This results in the selected
feature id being added to the selection multiple times (once for every
composite line style).
Since there are multiple features in your selection, the Ajax viewer
reports multiple features being selected ?\226?\128?\147 even though there
should only be one. This also prevents shift-select from working correctly
in the Ajax viewer.
To fix this, we need to prevent duplicate ids from being added to the
selection. When RenderForSelection calls StylizeVectorLayer, it uses a
FeatureInfoRenderer (a class derived from Renderer). We will add a virtual
method called RequiresCompositeLineStyleSeparation to Renderer which
defaults to returning true. For FeatureInfoRenderer, it will return false.
In DefaultStylizer::StylizeVectorLayer, it will check the
Renderer::RequiresCompositeLineStyleSeparation(). If it is true, it will
continue on to the composite line style separation code (if appropriate).
If it is false, it will simply call StylizeVLHelper one time.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/419#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
