[mapguide-trac] #711: Filtered Layer Still Show Tooltips and Selection
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 25 05:52:28 EDT 2008
   Reporter:  crispinatime  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.1
  Component:  Server        |     Version:  2.0.2
   Severity:  critical      |    Keywords:
External_id:                |
 We have an application creating a dynamic filter on a layer - e.g. the
 original layer in the session has a filter of "1=0" and using drop-down
 lists is filtered and the map refreshed, works great!
 However, all is good in the UI until a user hovers over or uses the
 selection tool over a feature that is not currently displayed (because it
 does not match the filter).  The problem is that the feature is still
 selectable (refreshes with a blue highlight) and also displays the tooltip
 if you hover over the empty space where the object was filtered out.
 This known example is using OLEDB points, on a MapGuide layout (no Fusion)
 on 2.0.2
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/711>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
