[mapguide-trac] #711: Filtered Layer Still Show Tooltips and
Selection
trac_mapguide at osgeo.org
Thu Sep 25 13:26:29 EDT 2008
#711: Filtered Layer Still Show Tooltips and Selection
Reporter: crispinatime | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: Server | Version: 2.0.2
Severity: critical | Resolution:
Keywords: | External_id:
Comment (by crispinatime):
All,
We have a 2.0.1 install on one of the dev machines - but I don't have
access right now...
Trevor, the "1=0" filter is fine in the original definition in the library
- and looks OK therfore in the first LayerDefinition display in the
session (we don't update the layer definition before load, only after
displaying the default map and the user selects a dropdown criteria).
It is once we rewrite the LayerDefinition in the session, and refresh the
map, the graphical layer display appears correct but the ability to get
ghost selections and tooltips is manifested. I should be able to get some
screen-shots if required.
The tooltip display code must be pretty clever if it can determine the
particular filter *in the current session* and apply that as well as the
location filter to the featurecource?!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/711#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
