[mapguide-trac] #710: PATCH: selection containing Datetime values causes exception
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 25 16:00:26 EDT 2008
 Reporter:  poulet1212                      |         Owner:  trevorwekel
     Type:  defect                          |        Status:  assigned
 Priority:  high                            |     Milestone:  2.2
Component:  Fusion                          |       Version:  2.0.2
 Severity:  major                           |    Resolution:
 Keywords:  mgdatetime selection exception  |   External_id:
Changes (by trevorwekel):
  * status:  new => assigned
  * owner:  => trevorwekel
Comment:
 A simpler fix is to call !ToString() method on the !MgDateTime object to
 return a human-readable string.
 Fix has been put into 2.0.x stream with
 http://trac.osgeo.org/mapguide/changeset/3349
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/710#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
