[mapguide-trac] #715: Ajax viewer pan/zoom executes two spatial queries on IE7
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 26 18:50:45 EDT 2008
   Reporter:  trevorwekel  |       Owner:  trevorwekel
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.0.1
   Severity:  minor        |    Keywords:
External_id:  1097918      |
 Using IE6 or IE7, the Ajax viewer executes two GETDYNAMICMAPOVERLAY
 requests for each pan/zoom.  This is readily evident using Fiddler.  Since
 two overlay requests are generated, all of the Fdo spatial queries are
 executed twice for every layer.  This reduces !MapGuide performance by a
 factor of two.
 The double request is necessary to support PNG alpha transparency under
 IE6.  It is not required for IE7 since alpha transparency is natively
 supported by IE7.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/715>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
