[mapguide-trac] #528: Grey images from mapserver with GETMAPIMAGE operation
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 3 04:10:25 EDT 2009
 Reporter:  trondat  |         Owner:
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  Server   |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by jbirch):
 Can you test this with 2.1?  If it is still a problem, can you please
 provide an .mgp file of the data you are using, as well as any scripts (or
 extent / scale ranges you are using for randomizing) that could be used to
 replicate the problem?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/528#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
