[mapguide-trac] #949: Installer: Remove file that reveals
unnecessary system information
trac_mapguide at osgeo.org
Fri Apr 3 05:49:29 EDT 2009
#949: Installer: Remove file that reveals unnecessary system information
Reporter: jbirch | Owner:
Type: task | Status: new
Priority: low | Milestone:
Component: Installer | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
This should be removed from the repo and manually extracted from the .wxs
file:
[http://svn.osgeo.org/mapguide/trunk/Installer/Support/Web/Apache2/htdocs/phpTest.php
/Installer/Support/Web/Apache2/htdocs/phpTest.php]
I'm sure there are other things we should be doing to reduce the standard
profile of a MapGuide Apache / install.
Maybe as a start, also set "ServerTokens Prod" in the server properties
and "Options -Indexes" for the MapGuide directory in httpd.conf, and
"expose_php = Off" in php.ini.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/949>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
