[mapguide-trac] #953: Installer: provide better Tomcat service install experience
MapGuide Open Source trac_mapguide at osgeo.org
Sat Apr 4 17:34:45 EDT 2009
 Reporter:  jbirch       |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:  2.2
Component:  Installer    |       Version:  2.1.0
 Severity:  minor        |    Resolution:
 Keywords:               |   External_id:
Old description:
> Currently, Tomcat gets installed, but no services are installed, and
> there is no check to ensure that a JRE/JDK is installed.  Users have to:
> - Install JDK
> - Run services.bat from Tomcat/bin
> - Manually configure Apache
> Although it would be great to offer a bare Tomcat option, this would take
> a lot of work (removing the options for Apache and PHP components during
> the install, providing and alternate configuration for TomCat with non-
> Apache MapAgent,  rewriting mapadmin in .jsp, etc).  In the meantime we
> can do a fair amount just by automating the installation of the Tomcat
> service when the JSP viewer is chosen with the Bundled install.
> Steps for this would looks something like:
> Pull the current version from:
>   HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development
> Kit\@CurrentVersion
> Get the value of JAVA_HOME from:
> Kit\{@CurrentVersion}\JavaHome
> Do a file search to ensure that %JAVA_HOME%\bin\java.exe exists
> If it doesn't exist, we can warn the user that the Java web extensions
> will not be available.
> If it does exist, we can run a custom action something like this to
> install the service (cobbled together from service.bat in Tomcat/bin):
>   [TomcatInstallDir]Tomcat/bin/tomcat6.exe //IS//[TC_SERVICE_NAME]
>      --DisplayName [TC_SERVICE_DISPLAYNAME]
>      --Description [TC_SERVICE_DESCRIPTION]
>      --LogPath=[TomcatInstallDir]\logs
>      --ClassPath=[TomcatInstallDir]\bin\bootstrap.jar
>      --Install [TomcatInstallDir]Tomcat/bin/tomcat6.exe
>      --StartClass org.apache.catalina.startup.Bootstrap
>      --StopClass org.apache.catalina.startup.Bootstrap
>      --StartParams start
>      --StopParams stop
>      --Startup auto
> And something similar for uninstall...
New description:
 Currently, Tomcat gets installed, but no services are installed, and there
 - Install JDK
 the install, providing and alternate configuration for Tomcat with non-
 Apache !MapAgent,  rewriting mapadmin in .jsp, etc).  In the meantime we
   HKEY_LOCAL_MACHINE\SOFTWARE\!JavaSoft\Java Development
 Kit\@!CurrentVersion
 Kit\{@!CurrentVersion}\!JavaHome
      --StartParams start
      --StopParams stop
      --Startup auto
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/953#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
