[mapguide-trac] #272: Improve speed of rendering engine by not using "select * from table"
MapGuide Open Source trac_mapguide at osgeo.org
Sat Apr 4 18:25:20 EDT 2009
 Reporter:  ksgeograf            |         Owner:  ronnielouie
     Type:  defect               |        Status:  new
 Priority:  medium               |     Milestone:  2.1
Component:  Mapping Service      |       Version:  2.0.1
 Severity:  minor                |    Resolution:
 Keywords:  render select style  |   External_id:
Comment (by jbirch):
 The solution seems pretty complex, and unless someone's been doing a lot
 of work in a local copy I'd guess that this won't be making it into 2.1...
 If this is the case, could you please reset or remove the Milestone?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/272#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
