[mapguide-trac] #959: IIS guest account has insufficent access to
web temp directory.
trac_mapguide at osgeo.org
Mon Apr 6 10:52:40 EDT 2009
#959: IIS guest account has insufficent access to web temp directory.
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: 2.1
Component: Installer | Version: 2.1.0
Severity: major | Keywords:
External_id: |
When installing with IIS/.net configuration, attempting to log into the
site administrator will fail. Turning on errors in php.ini reveals that
the IIS guest account does not have defined permissions for the temp
directory that is specified in php.ini
When installing, the temp directory should have access permissions defined
for the IIS guest account.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/959>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
