[mapguide-trac] #958: "The specified module could not be found" on Mapguide Site Administrator
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 9 16:00:42 EDT 2009
 Reporter:  JackOfHearts        |         Owner:
     Type:  defect              |        Status:  reopened
 Priority:  medium              |     Milestone:  2.1
Component:  Installer           |       Version:  2.1.0
 Severity:  trivial             |    Resolution:
 Keywords:  site administrator  |   External_id:
Comment (by jbirch):
 Sounds like the PHP MG module isn't loading correctly; wonder if there's a
 path issue that hasn't been solved.
 In your php.ini file:
 - hat is extension_dir set to?
 - are the extensions for both php_MapGuideApiEnvConfig.dll and
 php_MapGuideApi.dll enabled
 - if you set display_startup_errors=1 does it show more info?
 Create a file with these contents and see if !MapGuide extension shows as
 loaded:
   <?php phpinfo(); ?>
 What is the value of your PATH environment variable? You can attach it
 here by typing:
   echo %PATH% > mypath.txt
 What is the value of the registry key
   HKEY_LOCAL_MACHINE\SOFTWARE\PHP\5.2.5\!IniFilePath
 Can you attach directory listings of your PHP and PHP/Ext directories?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/958#comment:14>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
