[mapguide-trac] #966: Apache conf has incorrect path
trac_mapguide at osgeo.org
Thu Apr 16 15:10:42 EDT 2009
Reporter: martinmorrison | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.1
Component: Installer | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: | External_id:
Changes (by jbirch):
* cc: jng, jbirch (added)
* milestone: => 2.1
Comment:
What are the effects of this setting having a trailing slash?
One of the problems with the installer technology is that the properties
are set with trailing slashes and there is no way (short of a custom
action) to do string manipulation on the properties.
We could work around this by making the names "Web" and "Server" non-
configurable, and basing the Apache config off of MAPGUIDEROOTLOCATION.
I'm actually in favour of reducing the number of public properties in the
installer, so this might not be a bad approach.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/966#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
