[mapguide-trac] #966: Apache conf has incorrect path
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 17 09:58:28 EDT 2009
 Reporter:  martinmorrison  |         Owner:  jng
     Type:  defect          |        Status:  assigned
 Priority:  low             |     Milestone:  2.1
Component:  Installer       |       Version:  2.1.0
 Severity:  trivial         |    Resolution:
 Keywords:                  |   External_id:
Changes (by jng):
  * status:  new => assigned
  * owner:  => jng
Comment:
 We already are using a custom action to do this writing, it just means we
 have to strip the trailing slash from the Apache dir, and adjust the
 httpd.conf template to match.
 Replying to [comment:1 jbirch]:
 > What are the effects of this setting having a trailing slash?
 > One of the problems with the installer technology is that the properties
 are set with trailing slashes and there is no way (short of a custom
 action) to do string manipulation on the properties.
 > We could work around this by making the names "Web" and "Server" non-
 configurable, and basing the Apache config off of MAPGUIDEROOTLOCATION.
 I'm actually in favour of reducing the number of public properties in the
 installer, so this might not be a bad approach.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/966#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
