[mapguide-trac] #958: "The specified module could not be found"
on Mapguide Site Administrator
trac_mapguide at osgeo.org
Sun Apr 19 01:28:03 EDT 2009
#958: "The specified module could not be found" on Mapguide Site Administrator
Reporter: JackOfHearts | Owner:
Type: defect | Status: reopened
Priority: medium | Milestone: 2.1
Component: Installer | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: site administrator | External_id:
Comment (by jbirch):
There is one suspicious part, but I'm not sure if this is expected (since
IIS 5.1 doesn't have the concept of web service extensions AFAIK...
Action start 12:37:44: AddWebServiceExtension.
MSI (s) (F8:40) [12:37:44:610]: Invoking remote custom action. DLL:
C:\WINDOWS\Installer\MSIF.tmp, Entrypoint: AddWebServiceExtension
AddWebServiceExtension: Initialized.
AddWebServiceExtension: AddWebServiceExtension: GetData failed:
0x800cc801
MSI (s) (F8:40) [12:37:44:703]: Leaked MSIHANDLE (44210) of type 790541
for thread 2008
MSI (s) (F8:40) [12:37:44:703]: Note: 1: 2769 2: AddWebServiceExtension 3:
1
MSI (s) (F8:40) [12:37:44:703]: Note: 1: 2205 2: 3: Error
MSI (s) (F8:40) [12:37:44:703]: Note: 1: 2228 2: 3: Error 4: SELECT
`Message` FROM `Error` WHERE `Error` = 2769
DEBUG: Error 2769: Custom Action AddWebServiceExtension did not close 1
MSIHANDLEs.
The installer has encountered an unexpected error installing this package.
This may indicate a problem with this package. The error code is 2769. The
arguments are: AddWebServiceExtension, 1,
The other CAs (!RegisterScriptMaps, !SetCustomErrors, CreateVDirMapAgent,
etc) seem to run without error.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/958#comment:18>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
