[mapguide-trac] #968: Preview FeatureSource depends on Aggregates
trac_mapguide at osgeo.org
Tue Apr 21 13:27:40 EDT 2009
Reporter: ksgeograf | Owner: brucedechant
Type: defect | Status: closed
Priority: low | Milestone: 2.1
Component: General | Version: 2.0.2
Severity: trivial | Resolution: fixed
Keywords: preview viewer aggregate OGR extent | External_id:
Changes (by brucedechant):
* status: assigned => closed
* resolution: => fixed
Old description:
> The FeatureSource Preview has been updated to use the actual contents of
> the datasource for determining the preview extent. This is optimal for
> most FeatureSources, but some providers (like the OGR provider) does not
> support the requested aggregates.
> There should be a fallback method to use the spatial extent from the
> spatial context, if the aggregate function fails, as that is better than
> no preview at all (and actually correct for the OGR provider).
New description:
The !FeatureSource Preview has been updated to use the actual contents of
most !FeatureSources, but some providers (like the OGR provider) does not
Comment:
Fixed.
See changeset r3831
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/968#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
