[mapguide-trac] #811: Maestro breaks down on a significantly
large amount of resources.
trac_mapguide at osgeo.org
Wed Apr 22 16:16:21 EDT 2009
#811: Maestro breaks down on a significantly large amount of resources.
Reporter: jng | Owner: ksgeograf
Type: defect | Status: closed
Priority: medium | Milestone: Maestro-2.0
Component: Maestro | Version:
Severity: major | Resolution: fixed
Keywords: | External_id:
Changes (by ksgeograf):
* status: assigned => closed
* resolution: => fixed
Comment:
Fixed in r3836.
I have used the new API to avoid loading subfolders.
This has the drawback that all folders will appear to have content, but
may be empty after expanding the node. I can live with this minor defect,
so I consider the issue fixed, feel free to re-open if you disagree.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/811#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
