[mapguide-trac] #976: Installing Help after installing MapGuide
prompts for reboot
trac_mapguide at osgeo.org
Wed Apr 29 13:49:24 EDT 2009
#976: Installing Help after installing MapGuide prompts for reboot
Reporter: pagameba | Owner:
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Installer | Version: 2.0.2
Severity: trivial | Keywords:
External_id: |
If you install MapGuide without the Help component then re-run the
installer and add only the Help, the installer prompts you to reboot when
this should not be necessary.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/976>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
