[mapguide-trac] #1182: Maestro: expression editor throws MgNullPropertyValueException
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 4 12:32:39 EST 2009
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Old description:
> When trying to enumerate values in a particular property in the
> expression editor, an MgNullPropertyValueException is thrown if any null
> values exist for that property.
> This makes it difficult to work with that that contains these values; the
> current workaround I'm using is FDO Toolbox, but this can be difficult
> when the data isn't local.
> It would be great if Maestro's implementation of the expression editor
> could be modified to suppress these exceptions or, preferably, insert
> NULL as one of the choices in the value picker.
New description:
 When trying to enumerate values in a particular property in the expression
 editor, an !MgNullPropertyValueException is thrown if any null values
 could be modified to suppress these exceptions or, preferably, insert NULL
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1182#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
