[mapguide-trac] #1198: Maestro: r4431 throws exceptions when
creating new FeatureSource or LayerDefinition
trac_mapguide at osgeo.org
Mon Dec 14 17:14:03 EST 2009
#1198: Maestro: r4431 throws exceptions when creating new FeatureSource or
LayerDefinition
Reporter: jbirch | Owner: ksgeograf
Type: defect | Status: closed
Priority: high | Milestone:
Component: Maestro | Version:
Severity: blocker | Resolution: fixed
Keywords: | External_id:
Changes (by ksgeograf):
* status: new => closed
* resolution: => fixed
Comment:
Fixed with r4436.
I changed the way the initial resources are created.
Basically they are now created as temporary resources, before being
displayed.
This means that the xml now has to be valid enough to be stored in
MapGuide.
As a side-note, it is now possible to edit the FeatureSource template to
always select a certain provider (or create another template with a pre-
selected provider).
I also took this oportunity to change the default colors on the layer from
the previous black ones into something a little more colorful.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1198#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
