[mapguide-trac] #841: Web tier is not properly parsing the VERSION request parameter
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 11 18:57:11 EST 2009
 Reporter:  brucedechant  |         Owner:  brucedechant
     Type:  defect        |        Status:  assigned
 Priority:  medium        |     Milestone:  2.1
Component:  Map Agent     |       Version:  2.0.2
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:  1181011
Old description:
> The InitializeCommonParameters() method tries to extract the components
> of the VERSION parameter. The code works fine on Windows because the
> STRING object makes a copy of any STRING that is used in the constructor.
> Linux uses a reference instead and so a forced copy needs to be done.
> This impacts all requests.
New description:
 The !InitializeCommonParameters() method tries to extract the components
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/841#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
