[mapguide-trac] #853: Error when a dot is in Folderpath
trac_mapguide at osgeo.org
Sat Feb 14 07:13:06 EST 2009
Reporter: dl9ekd | Owner: ksgeograf
Type: defect | Status: assigned
Priority: low | Milestone:
Component: Maestro | Version:
Severity: critical | Resolution:
Keywords: | External_id:
Changes (by ksgeograf):
* status: new => assigned
* version: 2.0.1 =>
Comment:
Yes, I have seen this problem as well.
I will have to see if the MapGuide parser always expects there to be a
trailing slash for folders. If so, the hotfix will be the official fix.
Thanks for reporting the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/853#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
