[mapguide-trac] #850: MapGuide kml export not supported on
Google Earth 4.3 and later
trac_mapguide at osgeo.org
Sun Feb 15 23:58:47 EST 2009
#850: MapGuide kml export not supported on Google Earth 4.3 and later
Reporter: msuing | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: KML Service | Version: 2.0.2
Severity: major | Resolution:
Keywords: google earth, kml | External_id:
Changes (by jng):
* version: 2.0.1 => 2.0.2
Comment:
I can verify the same behaviour using MGOS 2.0.2 and Google Earth 5.0
Using the Sheboygan Dataset, my observations with the KML service are as
follows:
* GetMapKml: Layer information appears. No objects
* GetLayerKml: Same as GetMapKml. No objects.
* GetFeaturesKml: Objects do appear.
Since GetMapKml contains Network Links to GetLayerKml calls (which contain
Network Links to GetFeaturesKml calls), there must have been some breaking
change with regards to Network Links since GE 4.3
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/850#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
