[mapguide-trac] #850: MapGuide kml export not supported on
Google Earth 4.3 and later
trac_mapguide at osgeo.org
Tue Feb 17 23:56:12 EST 2009
#850: MapGuide kml export not supported on Google Earth 4.3 and later
Reporter: msuing | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: KML Service | Version: 2.0.2
Severity: major | Resolution:
Keywords: google earth, kml | External_id:
Comment (by jng):
Ok here's some extra information.
The kml returned by MapGuide does not actually do anything in GE when it
is first opened.
If you analyse the traffic in fiddler you will see dropped requests to the
mapagent
However, if you make that same request again (in an open instance of GE),
it will then work as normal.
If you saved that request as a kml file, the effect is identical.
Open it in GE for the first time. Nothing happens. Attempts to refresh
layers will show as dropped mapagent requests in fiddler.
Open it again in GE for the second time. Things work as expected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/850#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
