[mapguide-trac] #856: Fix Windows project settings not correctly
using /02 optimization for Release configurations
trac_mapguide at osgeo.org
Fri Feb 20 13:02:41 EST 2009
#856: Fix Windows project settings not correctly using /02 optimization for
Reporter: brucedechant | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.1
Component: General | Version: 2.0.2
Severity: minor | Keywords:
External_id: |
When the Windows projects were migrated from Visual Studio 2005 to Visual
Studio 2008 all of the projects that used the /O2 optimization setting for
Release configurations were lost. The Visual Studio 2008 UI will even show
that /O2 is set, but if you look at the actual command line options it is
not being set. This is a known issue with Visual Studio 2008.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/856>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
