[mapguide-trac] #857: View Feature of the schema report doesn't
work with joined features
trac_mapguide at osgeo.org
Fri Feb 20 18:27:08 EST 2009
#857: View Feature of the schema report doesn't work with joined features
Reporter: brucedechant | Owner: brucedechant
Type: defect | Status: assigned
Priority: low | Milestone: 2.1
Component: Feature Service | Version: 2.0.2
Severity: minor | Resolution:
Keywords: | External_id: 1200826
Old description:
> The DeterminePropertyFeatureSource() method of the ServerGwsFeatureReader
> object is not always setting the class name when it is called. This
> causes the "View Feature" of the schema report to fail with an exception
> message of:
> An exception occurred in FDO component. Item '' not found in collection.
New description:
The !DeterminePropertyFeatureSource() method of the
!ServerGwsFeatureReader object is not always setting the class name when
it is called. This causes the "View Feature" of the schema report to fail
with an exception message of:
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/857#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
