[mapguide-trac] #819: Cannot use empty color setting for background color for bitonal raster layer
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jan 8 13:04:27 EST 2009
layer
   Reporter:  ronnielouie  |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  Server       |     Version:  2.0.1
   Severity:  minor        |    Keywords:
External_id:  1154120      |
 When a "Map Window Background" color is desired for raster layer, the
 corresponding XML should be an empty color setting.  Attempt to save such
 a setting results in the following error:
  Error: An exception occurred in DB XML component.
         Error: XML Indexer:  Parse error in document at line, 19, char 20.
 Parser message: Element 'Color' is not valid for content model:
 '(((ExplicitColor|Band)|Bands),ExtendedData1)'
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/819>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
