[mapguide-trac] #797: Patch to change the active tool Cursor in
ajax viewer
trac_mapguide at osgeo.org
Thu Jan 8 13:08:55 EST 2009
#797: Patch to change the active tool Cursor in ajax viewer
Reporter: bscott | Owner:
Type: enhancement | Status: new
Priority: medium | Milestone: 2.1
Component: AJAX Viewer | Version: 2.0.2
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by tomfukushima):
The icons look pretty good. Our product designer may create a replacement
set that are a little more generic; but there probably won't be time.
Otherwise, if you could make them a little bigger so that they are clearer
that would be good. Also, I don't think that the pan cursor needs the +
on it.
Our product designer noted following problems that will need to be
corrected before submission:
1. Open the web layout in the browser. Select the Zoom rectangle mode
(notice that the cursor is correctly changed to the zoom rectangle
cursor). Do a zoom operation. Do a "zoom previous" operation. Notice that
even though the map is still in the "zoom rectangle" mode the cursor is
now incorrectly the select cursor.
1. Open the web layout in the browser. Select the zoom rectangle mode.
Select the measure distance task. Notice that the cursor is still the
zoom rectangle cursor even though the map is now in measure distance mode.
The above problems mention Zoom rectangle, but probably also affect the
other modes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/797#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
