[mapguide-trac] #797: Patch to change the active tool Cursor in ajax viewer
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jan 14 15:16:19 EST 2009
 Reporter:  bscott       |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  medium       |     Milestone:  2.1
Component:  AJAX Viewer  |       Version:  2.0.2
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by tomfukushima):
 Hi Bruno, Thanks for the changes. Problem 2 above was resolved, but I can
 still reproduce 1.  Try these steps...
  1. Open the Sheboygan sample map
  1. Select the Zoom rectangle mode
  1. Do a zoom rectangle operation to zoom in
  1. Click on the Zoom menu on the toolbar, and select "Previous View"
 Note that after the map zooms back to the previous view, the cursor is now
 the select cursor when it should still be the zoom rectangle cursor.  The
 same problem occurs with Zoom in mode, Zoom out mode, pan mode, etc.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/797#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
