[mapguide-trac] #726: MapGuide Stops Listening on 2811 (Client Connections)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jan 28 15:17:58 EST 2009
 Reporter:  rbranson  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:
Component:  Server    |       Version:  2.0.2
 Severity:  trivial   |    Resolution:
 Keywords:            |   External_id:
Changes (by amitmarty):
  * severity:  critical => trivial
Comment:
 After going through a lot of permutations and combination's.
 I finally replaced my mysql connector jar file with a older version.
 And now I am glad to say the problem has gone away. I have tried jmeter
 tests with upto 64 users in parallel trying to access the application and
 have not had the 2811 connections from tomcat go above 10.
 I am changing the sev. back to trivial as per the original ticket that was
 opened by someone else.
 Thank You
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/726#comment:20>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
