[mapguide-trac] #1039: Possible leak in selection
trac_mapguide at osgeo.org
Tue Jul 21 14:59:08 EDT 2009
Reporter: jng | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.0.2
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by brucedechant):
The MgSpatialContextReader object doesn't need to call Close() because the
destructor of the MgSpatialContextReader class automatically calls
Close(). When the GetFeatureExtents() method finishes the
MgSpatialContextReader object will go out of scope because it is a smart
pointer and the destructor will automatically be called.
The preferred programming practice is to call Close() on any reader when
finished, but in this particular case there is no harm in not calling it.
Regardless I will update the code to conform to the proper use of readers.
There may still be a leak in the selection code, but not calling Close()
is not the source of it.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1039#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
